The new version 1.8.6 works fine for generating jpegli files, including with XYB color coding (the files are exactly the same as those generated by cjpegli.exe), but those coded in XYB are displayed with a dramatic shif in color, i.e. 1.8.6 is able to correctly generate these files but not to read them (at least on widows 10). No problem for both writing and reading files generated in jpegli without XYB
thanks
simon
1.8.6 jepgli
Re: 1.8.6 jepgli
i can't reproduce, jpegli with XYB are correctly readed
simon
Re: 1.8.6 jepgli
I finally found that I can read jpeli XYB files correctly by activating "use ICC profile for monitor" in Settings/General/color management
(by default I let this tick box unchecked, as it is specified that this leads to some slow down)
Re: 1.8.6 jepgli
yes jpegli write icc profile
