1.8.6 About Panel Displays .ini path incorrectly if folder starts with a .
UTC
Post by UTC »
XnView: MP 1.8.6 - 64-bit
OS: Windows 11 - 64-bit
XnView launched with the -ini command line option when the path contains a folder starting with a period
Effect: XnView about panel displays incorrect path. Link to file does work however.
1. Open powershell and run command:
Start-Process -FilePath 'C:\Program Files\XnViewMP\xnviewmp.exe' -ArgumentList "-ini H:\APPCONFIG\.XnViewMP\xnview_rect_stack.ini"
2. XnView MP will open
3. Press F1 to open About Panel
Actual behaviour (bug): INI Filename will be displayed as: H:\APPCONFIGXnViewMP\xnview_rect_stack.ini
Expected behaviour: INI Filename should be H:\APPCONFIG\.XnViewMP\xnview_rect_stack.ini
Note: the link to the ini file does point to the correct location however
Within Settings - Paths [XnView settings] [Use. ini file in folder] set to custom
Pressing [Open Config file location] opens %USERPROFILE%\AppData\Roaming\XnViewMP
Not sure if this is expected behavior but seems inconsistent.
_________________________________________________
Re: 1.8.6 About Panel Displays .ini path incorrectly if folder starts with a .
right it's a bug in Qt API
