How to configure XnShell to convert to JPG format?
SoCu
Post by SoCu »
Hi, I have an image in CR2 format and I am converting it to JPG format from XnShell, but the result converted file the image looks darker.
This same CR2 image I have converted from XnView MP to JPG format, setting the export to high quality, and the image looks the same.
And the difference in the size of the converted file is larger from XnView MP
How can XnShell be configured so that the image converted to JPG looks the same as the original?
P.S. this is the CR2 format file, with which I have been testing, in case anyone wants to try and see the different results from XnView MP and XnShell
I leave this link, because I can't attach the file due to the type of extension that has
https://drive.google.com/file/d/1avFLip ... sp=sharing
Thank you.
Re: How to configure XnShell to convert to JPG format?
do you have changed the quality in XnShell?
SoCu
Post by SoCu »
Hi, I don't know where that setting is in XnShell, since I couldn't find that option I thought it was taken from the XnView MP configuration.
SoCu
Post by SoCu »
This is the XnShell menu that shows me the options, I do not know where to set the image quality
Can you tell me where to configure it to try to see if it does not change the image?
thank you
in 'Convert', you have the settings
SoCu
Post by SoCu »
You mean in this menu?
When I click on configuration, that button does nothing, it doesn't show any configuration window.
I don't know if it has something to do with the operating system, but I am using Windows 11.
please choose 'JPG' as output format
SoCu
Post by SoCu »
It only shows me two “JPG” formats, the one that I have put in the previous capture, that the button is active, but when pressing it it does nothing, and this other format “JPG”, that the configuration button is OFF, so it cannot be configured either.
you have "JPG - JPEG / JFIF" at the top of the list
SoCu
Post by SoCu »
Ok, I thought they were all together in alphabetical order, and that first block I missed.
I think I have the same settings in XnView MP and XnShell, and the size of the file that XnShell creates is much larger than the one created by XnView MP.
Anyway, once configured when converted the image is still darker, I have tried all the settings, and when converted from XnView MP to JPG format the image is displayed with the same light as the original, and from XnShell it is still darker.
SoCu wrote: Sat Mar 22, 2025 11:26 am I think I have the same settings in XnView MP and XnShell, and the size of the file that XnShell creates is much larger than the one created by XnView MP.
In XnViewMP, you should have configured that embedded thumbnail is used for Camera RAW. In XnShell, it's the full size
SoCu
Post by SoCu »
Hi, I don't understand very well the translation of your last comment.
But, the converted images, I think that being equally configured in XnViewMP and XnShell, are different.
The one converted with XnViewMP has the same color as the original, you can see the difference between the two opened in Photoshop.
In CR2, you have a embedded JPEG, and i think that XnView is configured to use it and not the full raw data
In XnShell, the full raw is always used. i'll add a setting
SoCu
Post by SoCu »
Thanks now I understand, it is faster to convert from XnShell, the bad thing is that now it does not create the images like the original, you have to pass them with other programs to match the color, so if there are many images you lose a lot of time.
SoCu
Post by SoCu »
Hi, I have seen and updated XnShell, I don't know if something new has been added, but after testing, it still shows the same result, from XnViewMP the conversion to JPG remains the same as the original CR2, it shows the same color, but from XnShell the conversion is still darker.
