Cropping an image
Bronimus
Cropping an image
Post by Bronimus »
Hi everybody
Cropping an image with a fixed ratio (e.g. 16 x 9) and afterwards swapping horizontal and vertical orientation (with <>) does not work whereas selecting free ratio for cropping you can swap the orientation correctly.
Kind regards / Schönen Gruß vom Bronimus
Windows 11 Home, XnViewMP 1.8.6 64-bit
Re: Cropping an image
