Hello! I use such setting: General-Startup-Start with file-Open: Viewer-Fullscreen
What really catches the eye is the very sloppy closing of a full-screen photo using the Esc button. There is a flashing of the current photo in different scales and only then closing. If you press not Esc but Alt+F4, then there is no such problem. Could you fix something in the algorithm for exiting this mode so that it closes quickly and cleanly? Or I would just ask to add a function so that in this mode the Esc button does the same as the Alt+F4 combination
Here is a sample video showing the problem.
Visual artefacts when Esc fullscreen in startup
mar1boro
mar1boro
Re: Visual artefacts when Esc fullscreen in startup
Ok, thank you. So it's known problem and the developer had some issues to leave that behavior. But it's still possible to emulate alt+f4 when esc.
