1.8.6: Abnormal file saving description line and failure to add an extension to the file (IFF (1st))
Seryi
Post by Seryi »
XnView: MP 1.8.6 - 64-bit
OS: Windows 11 - 64-bit
Abnormal file saving description line.
Effect: failure to add an extension to the file.
1. Open any image
2. Go File - Save As
3. Choose format IFF (1st)
Re: 1.8.6: Abnormal file saving description line and failure to add an extension to the file (IFF (1st))
sorry but i dont understand the problem...
Seryi
Post by Seryi »
The program substitutes the JPG extension to save IFF/TBI, but the program is limited to these extensions to open these formats.
Seryi wrote: Thu Mar 20, 2025 8:18 am The program substitutes the JPG extension to save IFF/TBI, but the program is limited to these extensions to open these formats.
Please send some screenshots
i can reproduce
to reproduce
filename shows A.png - OK
2. press Ctrl+Shift+S and select "IIF - Explore (TDI);&;Maya)" type
expected behaviour
filename to change to A.iif
ps. also there is typo in the format name in "Save as" dialog (it's correct in "Open" dialog though):
  • IIF - Explore (TDI);&;Maya)
    IIF - Explore (TDI) & Maya (*.iff;*.tdi)
  • WBMP - Wireless Bitmap (level;0))
    WBMP - Wireless Bitmap (level 0) (*.wbmp;*.wbm;*.wap)
Seryi
Post by Seryi »
Don't forget the WBMP extension with a similar problem.
fixed in 187
