I use XnView MP 1.8.6 in Win10
All photo formats can be viewed normally using XnView MP, except DNG which is very small. My monitor is 2560 x 1440. Assuming my DNG size is 5472x3648px, it should fill the monitor when viewed at 100%, but in reality it only takes up 1/3 of the monitor. However, other formats such as jpeg, RAW, and Tiff are all normal.
The result is close px DNG 100% smaller than Jpeg、RAW 30%
DNG 5472x3648px @100% auto fit monitor
jpeg 4096x3072px @41% auto fit monitor
jpeg 6240x4160px @ 30% auto fit monitor
RAF 6246x4170px @ 42% auto fit monitor
DNG file display small (Solved)
35OL35
Re: DNG file display small
File > Format settings... > Read > Camera RAW > Use --Full size
its for Convert/Batch convertcday wrote: Mon Mar 10, 2025 6:46 am File > Format settings... > Read > Camera RAW > Use --Full size
for Viewer tab and Preview pane - Camera RAW, use [Full size] in Settings > View
35OL35
same small
After changing Settings > View, which would seem to be the relevant parameter?
Or File > Format settings... > Read > Camera RAW > Use --Full size ?
35OL35
yes, but photo size nothing change
I was asking which of the above settings you tried changing, or did you change both?
35OL35
Aren't the two settings the same?
'Settings>View - Camera RAW' is used when loading an image in preview or image's tab
