Windows 10
XnViewMP 1.8.6 64bit Libformat 7.204
So my folders usually contain a mix of images/video. I scroll through them using mouse wheel and and exit program.
Sometimes when I exit xnviewmp, it seems to be locking access to the folder as moving the folder allows moving the files but fails to move/delete the source folder. This seems to mainly happen in folders with video, but not always.
Task Manager shows the task is removed from the "Apps" but stays as a "Background Process" until I manually "End Task". After which folder access is restored.
Is there a setting for this or is this a bug?
Exiting leaves background process that locks folder
win10tester888
Re: Exiting leaves background process that locks folder
you have XnView as background process?win10tester888 wrote: Tue Mar 11, 2025 5:49 pm Task Manager shows the task is removed from the "Apps" but stays as a "Background Process" until I manually "End Task". After which folder access is restored.
win10tester888
No, I run the program as normal. It appears in Task manager as an "Apps". When it exits normally it is removed from apps and terminates correctly. Sometimes exiting removes the process from "Apps" but it becomes/remains a "background process".xnview wrote: Wed Mar 12, 2025 9:55 amyou have XnView as background process?win10tester888 wrote: Tue Mar 11, 2025 5:49 pm Task Manager shows the task is removed from the "Apps" but stays as a "Background Process" until I manually "End Task". After which folder access is restored.
EDIT: (I am able to somewhat reproduce the issue.)
- Open folder with 1 image + 1 video.
- Double click image to start xnviewmp.
- Click "X" to end program. (Removed from "Apps", No background process)
- Use mouse scroll to scroll to video.
- Click "X" to end program. (Removed from "Apps", appears as background process)
you can reproduce it each time? I can't...win10tester888 wrote: Wed Mar 12, 2025 8:47 pm
win10tester888
Is there anyway to disable xnview's interaction with videos? I only use it as an image viewer. I only scroll pass videos to see the other images.xnview wrote: Fri Mar 14, 2025 12:52 pmyou can reproduce it each time? I can't...win10tester888 wrote: Wed Mar 12, 2025 8:47 pm
you can disable video in Settings>View>Filter
