Starting delay and Error "libpng warning: iCCP: known incorrect sRGB profile"
TommyD
Post by TommyD »
i started using xnviewmp on Linux with Ubuntu 18.04 and i have the same error since years. From time to time for reasons i don't understand startuing xnview takes several minutes. When i start xnview in a terminal i have this:
0.29.0 (git 9b548e5) - Multimedia Development Kit. Copyright (c) 2016-2024 WangBin(QtAV author) <wbsecg1 at gmail.com>
Build for: Linux x86_64; glibc2.24/2.35 libc++190000; Clang19.0.0 (++20240702031426+43b988821423-1~exp1~20240702151527.1781); 04:26:03 Jul  3 2024
==> 1,000000  1,000000  91,947750  96,000000  (0)
XNVIEW restoreGeometry before : 640 480
XNVIEW restoreGeometry after : 1920 1027
ARG[] = /opt/XnView/XnView
XNVIEW SIZE 1920 1027
########### BrowserWindow :: BrowserWindow
MENU install : 0x6de6e70
ThumbLoaderThread :: stop()
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 0, 0, 0, 127'
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 255, 255, 255, 255'
########### BrowserWindow :: ok create (640 480)
BrowserWindow :: changeVisibility()
########### BrowserWindow :: restoreState (1920 1027)
BrowserWindow :: restoreState => 1920 1027
                              => 1658 739
BrowserWindow :: restoreState ok => 1658 739
XNVIEW SIZE ok 1920 1027
The only thing thats "fixes" the problme is a reboot. Doesn't matter whether i use the DEB-File, TGZ-Archive or the AppImage.
Re: Starting delay and Error "libpng warning: iCCP: known incorrect sRGB profile"
you have the delay after
TommyD
Post by TommyD »
Thats correct. Why is there a delay?
do you have tried to rename the xnview.ini?
TommyD
Post by TommyD »
No, but i deleted the complete xnview folder. after that there is no start delay. but then all settings are gone.
i can't test it because at the moment the problöem doesn't occure.
you have no more the old xnview.ini?
TommyD
Post by TommyD »
When the Problem occurs i dont delete the old ini. I can rename it but that doesnt solve the Problem.
When i rename the ini to xnview.ini.old i can Start xnview. When i rename it back i have the Problem again. The question is: why? After a restart all works (with the old ini). Renaming is only a temporary solution.
TommyD wrote: Wed Mar 19, 2025 11:31 am When i rename the ini to xnview.ini.old i can Start xnview. When i rename it back i have the Problem again. The question is: why? After a restart all works (with the old ini). Renaming is only a temporary solution.
Please send me the xnview.ini when you have problems
