XnConvert 1.104
RoyalScam
XnConvert 1.104
Post by RoyalScam »
I'm seeing a HUGE bug in the macOS version of 1.104. I'm running macOS Ventura 13.7.4 on an Intel MacBook Pro.
See the .jp2 I'm loading vs. how it appears in XnConvert 1.104.
If .jp2 are no longer supported in XnConvert, I'll have to find another solution...
Re: XnConvert 1.104
RoyalScam wrote: Tue Mar 11, 2025 3:41 pm I'm seeing a HUGE bug in the macOS version of 1.104. I'm running macOS Ventura 13.7.4 on an Intel MacBook Pro.
please send us the jp2?
RoyalScam
Re: XnConvert 1.104
Post by RoyalScam »
Here you go. But it's not just these particular jp2 files, it's any jp2 file I try.
Also, I went back to 1.102 and they work just fine.
https://www.transfernow.net/dl/20250312eyveJDdh (Link good until March 19th)
Re: XnConvert 1.104
RoyalScam
Re: XnConvert 1.104
Post by RoyalScam »
Thanks. I notice in the bug report it's been "fixed' in XnView 1.8.7, but when will that be fixed/updated in XnConvert?
RoyalScam
Re: XnConvert 1.104
Post by RoyalScam »
xnview wrote: Thu Mar 13, 2025 4:06 pm :bugconfirmed: Thanks to your detailed description I can reproduce the problem.
I notice in the bug report it's been "fixed' in XnView 1.8.7, but when will that be fixed/updated in XnConvert, where I reported the bug in the first place?
Thanks.
Re: XnConvert 1.104
RoyalScam
Re: XnConvert 1.104
Post by RoyalScam »
xnview wrote: Thu Mar 27, 2025 8:54 am This problem is supposed to be fixed in XnView MP 1.8.7. Please check and confirm the bug fix here.
I am not using XnView MP. I am using XnConvert and that is where I found and reported the bug.
Re: XnConvert 1.104
RoyalScam wrote: Thu Mar 27, 2025 11:08 am
It is up to you whether you wish to test the fix now in XnView MP 1.8.7 Batch convert, or wait until the next XnConvert release, XnConvert and XnView MP Batch convert being nominally the same software although updated separately when convenient for Pierre.
