XnView: MP 1.8.6 64 bit
OS: Windows 10 22H2/64bit
Effect: Cant open the files in GIMP 2 to verify said files, get "Requested data exceeds size of file" error popup in-gimp (see attached)
1. open an image and save it to .DDS
2. try to open the image in GIMP.
3. you get the following errors in GIMP (see attached).
4. Opening and re-saving DDS files in Paint.net fixes the error and creates the missing mipmap layers.
Expected behaviour:
- For XnviewMP to correctly output/save .DDS files so they include mipmap layer. On a side not, I am able to open said files in GIMP 3 rc3 (and dont get the error) but the mipmap layers are still showing as not present.
- would be handy to have the ability choose DXT compression on single and batch actions.
XnviewMP 1.8.6: DDS files are missing mipmap layers.
b1k3rdude
Re: XnviewMP 1.8.6: DDS files are missing mipmap layers.
