RC2 : Tiled TIFF with width non-16-multiple skewed
pov
Post by pov »
I've had this problem for quite some time (at least 1.80) but I think it has always existed. I work frequently with Tiled RGB TIFF files (generated using JAI in particular) which width is not a 16 multiple (795 for instance) and when displayed they get skewed. Could you take a look at this problem to have it solved in RC3 or final version ?
I can send you an example by mail if you want.
XnView 1.82
Xyzzy
Post by Xyzzy »
You can also post the image on a service like imageshack.us
X.
Re: RC2 : Tiled TIFF with width non-16-multiple skewed
pov wrote:Hi,
Currently tiled tiff file is not supported
