Presets For Frame Effects (A Must Have)
Post by Hakim Antoine Said »
Hello everyone... :D
It's tedious to constantly configure the same effect over and over again, There should be an option to save settings (Presets). Presets would be the best way to save settings. Multiple presets for multiple custom configurations
Specifically, I'm referring to the frame effects
This option is extremely important because XnView MP takes me a long time, in other applications, i save presets and do it in less than 3 seconds, BUT in XnViewMP, i have to configure it from scratch for the same effect over and over again. Multiple presets for multiple custom configurations is the solution :!:
Please, Pierre. I'm really looking forward to that option
Thanks in advance, Pierre :wink:
! Presets For Frame Effects.png (334.45 KiB) Viewed 1088 times
Always Keep Going :wink:
Re: Presets For Frame Effects (A Must Have)
This problem is supposed to be fixed in XnView MP 1.8.8. Please check and confirm the bug fix here.
xnview wrote: Mon Apr 14, 2025 7:41 am This problem is supposed to be fixed in XnView MP 1.8.8. Please check and confirm the bug fix here.
Hello Pierre :wink:
Awesome... it works like a charm
that Option added called "Enlarge" is Wonderful
Thank you very much Pierre :!:
