Video fullscreen problem
Danny
Post by Danny »
If you disable the playback of movies for the browser's preview pane and then use the mouse to doubleclick a video file in order to have it displayed in fullscreen mode it won't work. All it does is make the background of the preview area black (with default color settings). Your mousecursor disappears as well (sometimes).
This did not happen with 1.80.3.
Doing the same with the keyboard's enter button works though.
XnView 1.82 <x>
ckv
Post by ckv »
Confirmed RC2 only. When trying to view video file in fullscreen directly from browser. "normal" fullscreen works.
reproduce
- Disable preview for video files in "Items dispayed"
- Open video file in fullscreen directly from browser.
ckv wrote:Confirmed RC2 only. When trying to view video file in fullscreen directly from browser. "normal" fullscreen works.
reproduce
What will be normal behaviour? Show or not show the video?
Xyzzy
Post by Xyzzy »
Show video if View>File list>Play video is checked.
I confirm also problem with disappearing cursor.
X.
Danny
Post by Danny »
reproduce
To show the fixed-image of the video in fullscreen mode at 100% zoom IMO.
ckit
Post by ckit »
reproduce
Confirmed.
My mouse disappears and I have to Alt+F4 to close XnView.
ckit
Post by ckit »
Xyzzy wrote:Show video if View>File list>Play video is checked.
X.
Confirmed.
ckit
Post by ckit »
Mouse Cursor bug still exists in RC3.
ckit wrote:Mouse Cursor bug still exists in RC3.
The video is played?
ckit
Post by ckit »
Yes.
Danny
Post by Danny »
Same here. Video plays as it should, but mouscursor still disappears completely.
Also: if you switch back to the browser the video still plays although it shouldn't since i've disabled playing videos in the preview pane (as mentioned in my initial post).
ckv
Post by ckv »
Mouse Cursor disappears because the fullscreen don't work. The fullscreen kind of opens in the preview area and the disappearing cursor is a side effect (normal behavior for fullscreen).
I hope that Pierre understands that the problem isn't disappearing cursor, but the not working quick fullscreen for videos when preview for video files in "Items dispayed" is disabled.
Danny
Post by Danny »
ckv wrote:the disappearing cursor is a side effect (normal behavior for fullscreen).
No it's not. The mouse cursor is supposed to come back up once you move your mouse.
Post by Guest »
Yeah. Thanks.
ckv
Post by ckv »
Hi everybody! Try this, go to options and disable "Browser / File list / Recognize only by extension" option. And try if the fullscreen works then.
