[1.8.7] Incorrect reg keys for context menu
alexis.coutinho
Post by alexis.coutinho »
The "Add 'Browse with XnViewMP' to context menu" toggle isn't working properly. When adding the menu entry, the HKEY_CLASSES_ROOT\Directory\background\shell\XnViewMP key incorrectly has a DefaultIcon subkey instead of an Icon value. And when removing the menu entry, the same HKEY_CLASSES_ROOT\Directory\background\shell\XnViewMP :bug: key is left behind. :wink:
Re: [1.8.7] Incorrect reg keys for context menu
alexis.coutinho wrote: Mon Mar 31, 2025 5:32 am The "Add 'Browse with XnViewMP' to context menu" toggle isn't working properly. When adding the menu entry, the HKEY_CLASSES_ROOT\Directory\background\shell\XnViewMP key incorrectly has a DefaultIcon subkey instead of an Icon value.
whats the problem with Icon?
alexis.coutinho
In Windows 10, Icon value works, DefaultIcon key doesn't (doesn't show icon next to "Browse with ..."). The context menu entry for right-clicking a directory has an icon because it's correctly configured, for example.
alexis.coutinho
This problem is supposed to be fixed in XnView MP 1.8.8. Please check and confirm the bug fix here.
alexis.coutinho
All good!
