1.8.7 - browser - session - startup without file - Open browser setting ignored
XnViewMP 1.8.7 64bit
Windows11 (24H2), display resolution 3840x2160, win scaling 150%
Browser - session (saved) - startup without file
'Open Browser' setting ignored
0. prerequisites
  • settings
    - Save session on program exit [Always]
    - Start w/o file - ☑ Open Browser (default)
  • tabs
    - have few Viewer tabs remembered and no Browser tab
1. run app w/o file
Viewer tabs will be restored - OK
Browser tab will not be opened
expected behavior
Instead of ignoring 'Open Browser' setting when starting w/o file + restoring prev_session, it could be like:
  • ☑ Open Browser
    • if Browser tab does not exist
      - open Browser tab with Directory as per settings
      - move focus to Browser tab
    • if Browser tab exists
      - (optional) overwrite Browser tab's Directory according to settings
         on one hand, this can be useful
         on the other, saved session data should not be modified on startup
  • ☐ Open Browser
      - open remembered tab(s) if any
      - keep focus at last active tab
NOTE: Browser tab is a bit special as there is one available, and it is reusable.
However, it's possible to have multiple Browser tabs, unfortunately they will share same startup settings.
Related
Re: 1.8.7 - browser - session - startup without file - Open browser setting ignored
yes normal, when session is restored 'start without file' is ignored.
it looks inconsistent:
  • when start w file
    app restores session AND opens new Viewer tab
  • when start w/o file
    app restores session AND ignores setting to open new Browser tab
woodlanddragon
Post by woodlanddragon »
Same here. When i choose open file with viewer ist always starts the browser. Additionally it dont shows the picture in the browser.
Greetings
woodlanddragon wrote: Tue Apr 22, 2025 1:55 pm When i choose open file with viewer ist always starts the browser. Additionally it dont shows the picture in the browser.
you need to fix associations
