nconvert export of XNView not working
CreativeWorld
Post by CreativeWorld »
in v1.8.7 of XNViewMP, when using the batch converter (Ctrl-U) and then exporting the options for nconvert, it does not work.
For "JPEG" it seems to work fine.
For "JPEGLI" it does not give any command line options. The batch file just reads "nconvert <filename>" w/o any command line options (e.g. like -q90).
Is this supposed to be like that?
Regards
CW
Re: nconvert export of XNView not working
This problem is supposed to be fixed in XnView MP 1.8.8. Please check and confirm the bug fix here.
