Can i use the original "#" in the Batch Rename
useryeh
Post by useryeh »
Since the "#" used for Numeric enumerator in Batch Renamer,
Can i use the original "#" for the file name in the Batch Rename? not replaced with number.
Thanks.
philomenasim
Re: Can i use the original "#" in the Batch Rename
Post by philomenasim »
Thanks.
Hello, in XnView Classic, the # symbol is used as a numeric enumerator in the Batch Renamer, so it will be replaced with numbers during the renaming process. Unfortunately, you cannot use the # symbol in the file name without it being replaced by a number.
