Title doesn't change when saving
XNViewMPUser
Post by XNViewMPUser »
XnView: MP 1.8.3 - 64-bit
OS: Windows 11 - 64-bit
When saving via the shortcut key "ctrl-s", the tab title doesn't change to the saved filename.
Effect: Title doesn't update
1. Press print screen to take a snapshot.
2. Open xnview, or have it open.
3. Paste the image via any method you want.
4. Observe the title of the tab "Clipboard x" where x is the number of times you've pasted a clipboard image so far.
5. Press "ctrl-s" to bring up the save dialog. Save the file anywhere with any filename.
6. Observe the * vanishes indicating the file has saved, but the tab renames named "Clipboard x".
Actual behaviour (bug): Tab title doesn't change upon saving. :bug:
Expected behaviour: Tab title changes according to the save filename because the tab title is usually the save filename.
XNViewMPUser
Re: Title doesn't change when saving
I have updated xnview to 1.8.8 - 64 bit. This reported bug is still present.
This problem is supposed to be fixed in XnView MP 1.9.0. Please check and confirm the bug fix here.
