exiftool.exe runs from AppData folder
Lewis
Post by Lewis »
When you select ExifTool from a file's properties, the .exe runs from a temporary folder inside C:\Users\<username>\AppData\... (on Windows).
This happens whether XnView MP is installed in Program Files or as portable from a different location.
IDK if this qualifies as a bug, but it's improper behavior. Executable files should stay in Program Files or wherever the portable folder is.
Re: exiftool.exe runs from AppData folder
how do you see that?
Post by michel038 »
I suppose that the Exiftool version that is in use is an auto-extract exe version (extract some files in a temporary folder) .
Since some weeks (months?), new versions of Exiftool are different : a small exiftool.exe and a folder (exiftool_files) for all needed files.
So with new versions of exiftool, it won't move, there is no need to extract files at each use ...
Lewis
Post by Lewis »
xnview wrote: Fri Apr 25, 2025 8:18 am how do you see that?
I have security software that alerts me when something wants to run from a user-writable location (roughly anything outside of "Program Files" and "Windows" folders).
