Filenumber indentation per folder in Batch Convert
Alesk
Post by Alesk »
When adding multiple folders in a Batch convert operation, I use this renaming pattern: {Folder name}-# and keep the folders structure
Currently, the enumerator is global for all files in all folders, the numbering of files in each subsequent folder starts where the previous ended.
I would like the enumerator to start from 1 in each folder, is it possible ? Did I miss an option somewhere ?
Re: Filenumber indentation per folder in Batch Convert
currently not possible
