[Feature] Option for ESC to always close (ALT+F4)
rotbus19
Post by rotbus19 »
As per title, an option to allow ESC to close immediately as though pressing `ALT+F4`.
Currently, it can take 3 x ESC to close the app (fullscreen -> Viewer -> Browser).
(This was discussed a looong time ago - https://forum.xnview.com/viewtopic.php? ... 9de3868d33)
Re: [Feature] Option for ESC to always close (ALT+F4)
I think it should be implemented by:
1. adding Quit command to Settings>Shortcuts
2. allowing to reassign its shortcut from Ctrl+Q to Esc
