Hello, nice to meet you, I really like your program. So, first of all, thank you very much!
What I would like to ask is if you could add an option in the print settings that says "Black and White Printing," as it is very important. I work at a stationery store, and your program helps me a lot. However, many people want their prints in black and white, and it's tedious to have to go to the printer properties each time to select black. So, if you could add that option at the time of printing, it would help us a lot!
Similarly, I have another suggestion, not as important but still useful. When selecting "Page Design" and then choosing "Simple - Customize," it would be great if there was a pointer that would allow you to enlarge and shrink the image, automatically updating the width and height, without having to manually type the values. Also, having an option for "Number of Copies" would be helpful, so we can print multiple copies within the page if they fit. It's just a suggestion, but the black and white printing option is definitely a priority. Thank you in advance!
Suggestion to Improve Print and Page Design Options
Miinoru
