-capture= option
smithcferg
-capture= option
Post by smithcferg »
Could option -capture=import be added?
"xnviewmp -capture=import -ini=importpics.ini" could open import/sort directly with customized-for-import ini file, close xnviewMP when capture is finished?
Thanks so much for this fine software
smithcferg
Re: -capture= option
Is there a way the import/sort utility could be made to open to open as the default view in xnviewmp, and closing out from import/sort would close out xnviewmp? This would allow calling on import/sort and closing it easily when this is the only operation that needs to be accomplished.
Thanks for all your work on this program. I am amazed at your dedication to keep updating this program over time.
