I've used the CadSoft Tools plugin for CGM files before in Irfanview, it is registered properly, and I placed the files in the Plugins folder of XnConvert. When I open some CGM files the program won't convert them, as it says they are not images. How do I ensure that XnConvert can see the plugin as registered? I have CS_Manager installed and I can see that the plugin is registered, is it because I previously registered it for Irfanview? Not sure if I need to un-register it somehow. Thanks
Unable to View/Convert CGMs After Registering Plugin
capSAR
Re: Unable to View/Convert CGMs After Registering Plugin
is it CADImage.dll?
capSAR
No, I'm using CS_CGM.dll since I only work with CGMs at the moment, I didn't register CADImage or download it.
ok, i found the problem, it will be fixed...capSAR wrote: Thu May 01, 2025 2:37 pm No, I'm using CS_CGM.dll since I only work with CGMs at the moment, I didn't register CADImage or download it.
