With the latest update XnviewMP has introduced a delay after second file (and any later) is deleted consecutively in the image viewer. It seems as if it is waiting for something.
The delay spans at least 2-3 seconds and is consistent in duration for all subsequent deletes. Only the first delete is consistent with past behavior.
Please fix it, it is very jarring!
1.8.8 Second and subsequent file deletes introduce a seconds long delay
brazenvoid
Re: 1.8.8 Second and subsequent file deletes introduce a seconds long delay
you have not the problem with 1.8.7? how do you see that there is a delay?
