WIsh I knew the version number, but on my Mac the "about XnView" is grayed out and cannot be selected.
Anyways, it is the newest version. We are now in May 2025.
Updated to the new version, and suddenly now many of the 4 thumbnails on folders are smaller. In some cases all 4 are small. In other cases all 4 are big. And in some cases they are both small and big.
What could be the reason for this?
I did not have any issues with this earlier.
Se examples attached.
And when are you coming with generation of folder thumbnails from video files? Please consider it.
Folder thumbnails suddenly smaller
Bactuz
Re: Folder thumbnails suddenly smaller
by default, embedded thumbnail is used, so you can disable 'Settings>Thumbnail>Use embedded thumbnail'Bactuz wrote: Tue May 06, 2025 11:03 pm Updated to the new version, and suddenly now many of the 4 thumbnails on folders are smaller. In some cases all 4 are small. In other cases all 4 are big. And in some cases they are both small and big.
okAnd when are you coming with generation of folder thumbnails from video files? Please consider it.
Bactuz
Thank you so much for a fix here.
Embedded gone, thumbs large again. Sweet.
So, why embedded by default? Maybe just change that?
Thanks for great software!
