When renaming a file, one presses SHIFT-TAB to goto the previous file. Normally this would advance to the file to the left, and eventually wrap around to the previous line so that all filenames could be accessed in reversed order. Currently it advances to the file above, i.e. in the previous row. This makes SHIFT-TAB-bing effectively useless in a grid view of files.
related: viewtopic.php?p=205903#p205903
SHIFT-TAB key navigates previous row, instead of previous file while renaming
LysolPionex
Re: SHIFT-TAB key navigates previous row, instead of previous file while renaming
This problem is supposed to be fixed in XnView MP 1.9.0. Please check and confirm the bug fix here.
