Disable autorefresh in XnView MP
Lucas
Post by Lucas »
In the "old version" I could go into Options, browser and disable the auto refressh option.
In the latest MP version, I can't fined Options (Unless it's now settings) and I can't find where i can disable the autorefresh.
Any guidance would be helpful. Thank you in advance.
Scenario"
Folder with 100 photos.
I need to change the names of series of photos (9 at a time) AND I need them to stay in the visual order they first presented when I opened the folder.
What happens now is the folder autorefreshes after each batch name change causing the photos go go out of original visual order, and I have to scroll through the folder to find the next batch to change.
Re: Disable autorefresh in XnView MP
Lucas wrote: Mon May 19, 2025 7:54 pm In the "old version" I could go into Options, browser and disable the auto refressh option.
'Auto refresh' was in Classic not MP, it was an old setting
you need to use Custom as sort order
