1.9.0 "Find similar files" can't distinguish down-converted copies of HEIC file
rsbrux
Post by rsbrux »
"FInd similar files" is unreliable when examining photos converted from HEIC to JPG
Effect: duplicate photos are not identified.
1. Open this directory in XnView MP.
2. Click on "Tools" - "Find similar files".
3. Select "Similar image content".
4. Set similarity to 60%.
5. Click "OK".
Actual behaviour (bug): XnView reports "No files found!"
The files ending in "IMG_NNNN.jpg" (5712x3213) were converted from the original Apple HEIC format into JPG using XnViewMP's batch conversion feature.
Those without "IMG_NNNN" (2730x1536) were converted by Apple for inclusion in a "Shared album".
XnViewMP 1.9.5 64-bit
running under Windows 11 Pro x64 25H2
Re: 1.9.0 "Find similar files" can't distinguish down-converted copies of HEIC file
we need some sample files
rsbrux
Post by rsbrux »
See the hyperlinked text "this directory" in my original post.
This problem is supposed to be fixed in XnView MP 1.9.2. Please check and confirm the bug fix here.
rsbrux
Post by rsbrux »
looks good, thanks!
