1.9.0 Crashes on opening Export
rotbus19
Post by rotbus19 »
1. open any JPEG
2. CTRL + ALT + S (Export...)
3. crash
Removing WEBP from Formats stopped the crash for me.
Note - I submitted a crash dump when the crash first happened a few minutes ago.
Re: 1.9.0 Crashes on opening Export
I cannot reproduce
i can't reproduce too, please send me your xnview.ini
rotbus19
Post by rotbus19 »
OK, I wiped my old XnView install, reinstalled and started with a totally clean user folder.
I changed a few things, mostly adjusting what is displayed on toolbars, etc. I then added WEBP to supported formats, opened a JPEG, CTRL+ALT+S and then it crashed - I sent the auto crash report just now.
Here are my settings -
XnViewMP-webp-crash-settings.zip
(7.78 KiB) Downloaded 185 times
the problem is that you have removed jpeg
rotbus19
Post by rotbus19 »
Confirmed. Thank you very much.
I didn't realise I'd done that - I think I just saw the 'JFIF' and unchecked it and saw that Jpegli was still available. Unchecking JPEG breaks others things - e.g. compression value for all other formats is broken, has no effect.
This problem is supposed to be fixed in XnView MP 1.9.1. Please check and confirm the bug fix here.
rotbus19
Post by rotbus19 »
Confirmed fixed. Many thanks.
