Cut/Crop Presets no longer working
SebSebsensen
Post by SebSebsensen »
Hey there,
I noticed that in versions newer than 1.82 the (or better some) saved presets for cropping won't work anymore, at least as long as its "higher than wide" and in pixel mode (e.g. my frequently used presets of 2304x3456 and 2448x3996 for two of my cameras when I need to crop something out of the RAW files while maintaining a standard size for these models). It will instead pick some seemingly random values, looks like the same ration but the wrong way round.
The saved presets in the opposite orientation (e.g. 3996x2248) work as always.
Could you please look into that? At the moment this keeps me from updating to current versions.
thanks & regards
Seb
Re: Cut/Crop Presets no longer working
Please describe the way to reproduce
SebSebsensen
I have an image of in my example of 4896x3264 pixels.
I got to crop mode with Ctrl+x
I select my preset of 2176x3264
It instead returns a selected area of 2176x1451
A similar thing (same phenomenon, slightly different numbers) happens with all of my presets with height > width.
Version 1.82 and lower return the expected selected area.
I've added a 7z file with two screenshots (the board software/its settings don't seem to accept *.wepb and I did not want to waste too much space).
Thanks for looking into it!
This problem is supposed to be fixed in XnView MP 1.9.2. Please check and confirm the bug fix here.
