how do i convert .art so i can view them with xnview?
3D
Post by 3D »
is there a batch, or a program that can convert alot of .art images or view them, xnview tells me “format of the file cannot be determined”. but in the supported formats .art is listed twice.. :(
Several for one---
:arrow: 3D
:) Hello !
- There are indeed two supported formats for the *.art extension, as “Artisan” and “Crayola”.
- But it's quite possible that your pics be else, let's say some other owner's format having the same extension…
- I didn't see any plugin DLL for the (supported) *.art, except I mistake.
- Anyway, I recommend you to send (a) sample(s) to Pierre in order he tries to parse this format… webmasterATxnviewDOTcom
:mrgreen: Kind regards,
Re: how do i convert .art so i can view them with xnview?
3D wrote:is there a batch, or a program that can convert alot of .art images or view them, xnview tells me “format of the file cannot be determined”. but in the supported formats .art is listed twice.. :(
XnView can open only one type of art files. If your image files are AOL art, it won't open it.
@Pierre: What's the full name of the art files that XnView can open (all the topics tell that AOL Art files cannot be opened, but never provide the info which Art files can be opened)?
See related topics
- AOL art-files
- view .art images?
- Won't open art image files
