Category Tab display
ThierryM
Post by ThierryM »
I am using XnView MP V1.9.1 on Windows 10.
The display of the categories in the category tab suddently switches to use an interline format wich is very large. It means I can see only very few values in the window. It is not the same in the Infomations window which still displays using normal interline.
I tried to restart application and PC, remove/add the category window but there is no way to restore initial interline.
I hope I have been clear enough, please help to restore initial state.
Thanks a lot
Re: Category Tab display
Post by michel038 »
If you have few custom settings, you can rename your xnview.ini file to xnviewini.old before starting XnViewMP.
A new xnview.ini will be created... and perhaps the problem will be solved
Otherwise, maybe a category name contains many blank characters or special characters that add a line break ?
ThierryM
Post by ThierryM »
Hello Michel,
Thanks for your quick feedback. It allowed me to find the issue.
Restoring a new xnview.ini didn't fix the issue when using my xnview.db file. So I searched in latest entry of my category DB and I found an unexpected value. After deleting it, the problem has been fixed. I was very lucky the find this value quickly ! I don't know what was wrong in this value ...
Again, thanks a lot.
