Friends, have you ever turned off or turned on some features of XnView?
But every time I reset Windows, I have to readjust the XnView functionality according to my daily usage habits,
This is a very troublesome and time-consuming matter,
So, is there any way to save or export the current configuration of XnView application,
After resetting Windows, we can directly import the XnView configuration file without having to make too many settings on XnView again
Can the function of saving the current application settings be introduced
wintab
Re: Can the function of saving the current application settings be introduced
you can save your settings, Settings>Paths - current location
