Collapse
human93657
Collapse
Post by human93657 »
Please collapse action list at progrup startup.
Or add a feature to remember collapse/expand state of an action.
would help me a lot with long list of actions
marsa
Re: ToDo list
Post by marsa »
human93657 wrote: Mon Jun 09, 2025 11:44 am Please collapse action list at progrup startup.
I was thinking about this too. I use a few saved presets, each with 5+ actions, and I often need to manually edit one of the last actions per image.
If the dev considers this, the best-case scenario for me would be:
1. The expand/collapse state of every action is saved per action in the preset files. Thus, when you reload a saved preset, the state of every action is preserved.
2. A new button to expand/collapse all actions in the list at once (maybe on top of the current buttons, to the left of the "Add action" button).
Thanks for the great program. Cheers!
Re: Collapse
Re: Collapse
This problem is supposed to be fixed in XnView MP 1.9.3. Please check and confirm the bug fix here.
