Deleting doesn't move to recycle bin
david3
I'm running: XnViewMP-linux-x64.deb 1.9.2
Deleting an image doesn't send it to the recycle bin, but rather permanently deletes it.
Re: Deleting doesn't move to recycle bin
File is local? do you have gio tool?
david3
Yes, the file is local. I do have the gio tool.
which linux ditribution do you have?
david3
Debian Trixie
could you start XnView from terminal and send the logs when you try to delete a file?
david3
Here's the log, as requested.
That is deleting a file on a locally attached USB hard drive (doesn't send it to the recycle bin).
I have noticed if I delete a file on the system SSD drive, it does send the deleted file to the recycle bin. Here's a log of that, too.
0.32.0 (git 0e9a8e6) - Multimedia Development Kit. Copyright (c) 2016-2025 WangBin(QtAV author) <wbsecg1 at gmail.com>
Build for: Linux 4KB x86_64; glibc2.24/2.41 libc++210000; Clang21.0.0 (++20250321082721+03557169e0ad-1~exp1~20250321082842.799); 10:27:00 Mar 22 2025
==> 1.000000 1.000000 91.727547 96.000000 (0)
XNVIEW restoreGeometry before : 640 480
XNVIEW restoreGeometry after : 1920 1062
ARG[] = /opt/XnView/XnView
XNVIEW SIZE 1920 1062
########### BrowserWindow :: BrowserWindow
MENU install : 0x3cbe5b10
CURRENT CHANGED -1
ThumbLoaderThread :: stop()
CURRENT CHANGED -1
QObject::connect: No such signal InfoPropertiesView::itemDoubleClicked(QTreeWidgetItem*,int)
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 0, 0, 0, 127'
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 255, 255, 255, 255'
########### BrowserWindow :: ok create (640 480)
###### CHECK CHILDRENS 0
###### CHECK CHILDRENS ok (0)
BrowserWindow :: changeVisibility()
########### BrowserWindow :: restoreState (1920 1062)
BrowserWindow :: restoreState => 1920 1062
=> 1658 819
BrowserWindow :: restoreState ok => 1658 819
XNVIEW SIZE ok 1920 1062
### BrowserWindow :: onStart go
#### onFavoriteDockVisible (1)
BookmarkNode::BookmarkNode : 0x3cde7f80
#### onCategoryFilterDockVisible (1)
#### onCategoryDockVisible (1)
########### BrowserWindow :: restoreState (1920 1020)
BrowserWindow :: restoreState => 1920 1020
=> 1609 628
BrowserWindow :: restoreState ok => 1609 628
BrowserWindow :: onStart 2
setPathname </mnt/x/test/>
### ThumbLoaderThread :: setFileList(0)
### ThumbLoaderThread :: setFileList() wait
######ThumbLoaderThread :: run : 3ccc0f70
######ThumbLoaderThread :: forever : 3ccc0f70
** start condition wait
### ThumbLoaderThread :: setFileList() after wait
** start condition wake one 2
## OPEN FOLDER
######ThumbLoaderThread :: forever 2 : 3ccc0f70
CHECK <0>
## Check folder
## Check companion 0
## Check companion ok 0
## OPEN DB FOLDER ok 0
## UPDATE DB FOLDER ok 0
## OPEN FOLDER ok 0
## updateLabel 0
## updateLabels ok 0
SORT the list...
STD::SORT... 4
STL::SORT... 0
SORT the list... 0
SORT the list... 0
BitmapLoadThread :: stop()
@@ BitmapResizeThread:: clear
Create children /
Create children /mnt/
Create children /mnt/x/
Create children /mnt/x/test/
## UPDATE ==> (test)
###### CHECK CHILDRENS 28
==> 7 (lib64) -> 7 (lib64)
==> 0 (android) -> 7 (temp)
dataChanged2 ==> 1 (download) -> 5 (movies-mkvmerge)
###### CHECK CHILDRENS ok (18)
## OPEN FOLDER done 31
### ThumbLoaderThread :: setFileList(3)
### BrowserWindow :: finish
### ThumbLoaderThread :: setFirstItemToLoad
### ThumbLoaderThread :: setFirstItemToLoad ok
CHECK <3>
### START 3
######ThumbLoaderThread :: start : 3 0 2
LOAD INFO </mnt/x/test/test-1.png>
10 IHDR 13
29 IDAT 90194
LOAD INFO </mnt/x/test/test-1.png> ok
ThumbLoaderThread - ADD into DB (-1)
LOAD INFO </mnt/x/test/test-2.png>
10 IHDR 13
29 IDAT 90194
LOAD INFO </mnt/x/test/test-2.png> ok
LOAD INFO </mnt/x/test/test-3.png>
10 IHDR 13
29 IDAT 90194
LOAD INFO </mnt/x/test/test-3.png> ok
CURRENT CHANGED 1
######### CategoryModel :: checkAndSave()
MyView::set LOAD FULL /mnt/x/test/test-2.png
## BitmapLoadThread :: load -1 -1
## Bitmap :: load 0
###### GFF:load </mnt/x/test/test-2.png>
####LOAD </mnt/x/test/test-2.png> 0
## BitmapLoadThread :: loaded 651 985
## MyView::onLoaded </mnt/x/test/test-2.png> </mnt/x/test/test-2.png> </mnt/x/test/test-2.png> (1)
## MyView::onLoaded ok
### resetViewport (0x3cdbbbf0) ==> 706 281 (186 281) 0 0
############################################ InfoPropertiesView
##### BUILD HISTO
##### BUILD HISTO ok
## onItemPressed
MENU install : 0x3cee4720
Create window finished
==> 1920
### resetViewport (0x3d404810) ==> 1920 930 (615 930) 0 0
SORT the list...
STD::SORT... 4
STL::SORT... 0
SORT the list... 0
SORT the list... 0
######ThumbLoaderThread :: run : 3d3c58f0
######ThumbLoaderThread :: forever : 3d3c58f0
setCurrentFilename </mnt/x/test/test-2.png>
#### onCurrentChanged 1
############### UPDATE MENU ############
getNext => 4
==> 0x3cf586a0
##ADD to cache 1 /mnt/x/test/test-2.png
P /mnt/x/test/test-2.png (651 985)
setCurrentFilename </mnt/x/test/test-3.png>
#### onCurrentChanged 2
MyView::change /mnt/x/test/test-3.png
## Bitmap :: load 0
###### GFF:load </mnt/x/test/test-3.png>
####LOAD </mnt/x/test/test-3.png> 0
getNext => 4
==> (nil)
#### check gio 2
====> 1 1
## ==> gvfs-trash has problem!!deleteIndexes 1 - 1
### ThumbLoaderThread :: setFileList(2)
deleteIndexes 5
### onFolderChanged /mnt/x/test/
############################################ onTimerDirectoryChanged 1
######## checkChildren
############################################ onTimerDirectoryChanged ok
CheckContent...
## Check folder
SORT the list...
STD::SORT... 4
STL::SORT... 0
SORT the list... 0
SORT the list... 0
CURRENT CHANGED 0
### checkChanged : 1
### ThumbLoaderThread :: updateFileList
### ThumbLoaderThread :: updateFileList ok
CHECK <0>
SAVE : 1920 1018
BrowserWindow :: saveState => 1920 1018
=> 1609 626
## BaseViewWindow :: ~BaseViewWindow()
######ThumbLoaderThread :: run : 3d3c58f0 OK
QMutex: destroying locked mutex
## BaseViewWindow :: ~BaseViewWindow() ok
AbstractViewWindow :: ~AbstractViewWindow()
######ThumbLoaderThread :: run : 3ccc0f70 OK
BookmarkNode::~BookmarkNode : 0x3cde7f80
MENU install : 0x1950ab10
CURRENT CHANGED -1
CURRENT CHANGED -1
=> 1658 819
BookmarkNode::BookmarkNode : 0x199098f0
=> 1609 628
setPathname </home/david/Downloads/>
######ThumbLoaderThread :: run : 195e3c70
######ThumbLoaderThread :: forever : 195e3c70
## OPEN FOLDER
######ThumbLoaderThread :: forever 2 : 195e3c70
CHECK <0>
## Check folder
## OPEN FOLDER ok 0
## updateLabel 0
SORT the list...
STD::SORT... 4
STL::SORT... 0
SORT the list... 0
SORT the list... 0
Create children /home/david/
Create children /home/david/Downloads/
## UPDATE ==> (Downloads)
## OPEN FOLDER done 5
CHECK <3>
### START 3
LOAD INFO </home/david/Downloads/test-1.png>
10 IHDR 13
29 IDAT 90194
LOAD INFO </home/david/Downloads/test-1.png> ok
LOAD INFO </home/david/Downloads/test-2.png>
10 IHDR 13
29 IDAT 90194
LOAD INFO </home/david/Downloads/test-2.png> ok
LOAD INFO </home/david/Downloads/test-3.png>
10 IHDR 13
29 IDAT 90194
LOAD INFO </home/david/Downloads/test-3.png> ok
CURRENT CHANGED 1
MyView::set LOAD FULL /home/david/Downloads/test-2.png
## Bitmap :: load 0
###### GFF:load </home/david/Downloads/test-2.png>
####LOAD </home/david/Downloads/test-2.png> 0
## MyView::onLoaded </home/david/Downloads/test-2.png> </home/david/Downloads/test-2.png> </home/david/Downloads/test-2.png> (1)
### resetViewport (0x196d7b40) ==> 706 281 (186 281) 0 0
##### BUILD HISTO
## onItemPressed
MENU install : 0x198afdb0
==> 1920
### resetViewport (0x19d03ec0) ==> 1920 930 (615 930) 0 0
SORT the list...
STD::SORT... 4
STL::SORT... 0
SORT the list... 0
SORT the list... 0
######ThumbLoaderThread :: run : 19e15be0
######ThumbLoaderThread :: forever : 19e15be0
setCurrentFilename </home/david/Downloads/test-2.png>
getNext => 4
==> 0x1972a4f0
##ADD to cache 1 /home/david/Downloads/test-2.png
P /home/david/Downloads/test-2.png (651 985)
setCurrentFilename </home/david/Downloads/test-3.png>
MyView::change /home/david/Downloads/test-3.png
## Bitmap :: load 0
###### GFF:load </home/david/Downloads/test-3.png>
####LOAD </home/david/Downloads/test-3.png> 0
getNext => 4
==> (nil)
#### check gio 2
====> 1 0
deleteIndexes 1 - 1
deleteIndexes 5
### onFolderChanged /home/david/Downloads/
CheckContent...
## Check folder
SORT the list...
STD::SORT... 4
STL::SORT... 0
SORT the list... 0
SORT the list... 0
CURRENT CHANGED 0
CHECK <0>
SAVE : 1920 1018
=> 1609 626
######ThumbLoaderThread :: run : 19e15be0 OK
######ThumbLoaderThread :: run : 195e3c70 OK
BookmarkNode::~BookmarkNode : 0x199098f0-
Ok, gio doesn't support to delete a file from USB hard drive (FAT32 or exFAT)
david3
The USB hard drive has a BTRFS file system, same as the system SSD drive that sends files to the recycle bin.xnview wrote: Mon Jul 07, 2025 7:53 am Ok, gio doesn't support to delete a file from USB hard drive (FAT32 or exFAT)
could you gio on with a file on your usb drive?
david3
If I try "gio trash (filename)" it gives an error:
Trashing on system internal mounts is not supported
Is that what you mean?
thanks, XnView uses gio to delete file in recycle bin
david3
It seems it doesn't like using the recycle bin for deleting from mount points. It's unclear if it's a btrfs thing (mounting a subvolume), or more general.
Possibly related:
https://gitlab.gnome.org/GNOME/glib/-/issues/1885
Possibly related:
phototweak
In Linux Mint 22.2 Cinnamon and working on a directly-installed SATA HDD (separate from the OS NVMe), deleted files are not put in Trash as selected. Is there a solution? The terminal shows messages like these:
## ==> gvfs-trash has problem!!====> 1 127
KPAH
can we have any update on this?
for me, XnView in Linux does not trash any files from any types of drives, regardless how they are attached or mounted, of the file system used.
Arch Linux, KDE, installed on BRTFS partition. I remember it working so a liitle while when i was on Ext4.
