Preview sometimes doesn't show selected image
Paran902
Post by Paran902 »
Using v1.9.2 64-bit for Windows.
When in Browser mode, the Preview pane not always shows correct image when doing multiselection with Shift+Click on the Thumbnails list.
Steps to reproduce:
-start app in Browser mode
-make sure the list of thumbnails is visible
-make sure the Preview pane is visible
-select first image using mouse. The preview is correct.
-Shift + Click multiple thumbnails, so that last selected image is on second or later row of thumbnails
Result:
-The preview will show last image of the first row.
Expected result:
-The preview should show last image selected.
Above works randomly, but it's fairly easy to reproduce, just keep clicking with Shift+Click.
Re: Preview sometimes doesn't show selected image
This problem is supposed to be fixed in XnView MP 1.9.3. Please check and confirm the bug fix here.
