XnViewMP category groups font size
Daimonicon
Post by Daimonicon »
Is there a way to adjust the font size. I use the theme ‘hell’ (german) should be “hell” or ‘light’ in english. I can't get through this confusing mess regarding the stylexx~.qss.
Re: XnViewMP category groups font size
you would like to change font size in category sets?
Daimonicon
xnview wrote: Sun Jun 22, 2025 8:50 am you would like to change font size in category sets?
No, primarily ‘Category Groups’ (red). But also the left-hand tree view (blue).
Alternative screenshot - https://prnt.sc/0SJI8CiYukyJ
which windows font scaling do you use?
Daimonicon
xnview wrote: Tue Jun 24, 2025 8:28 am which windows font scaling do you use?
125%
Daimonicon wrote: Tue Jun 24, 2025 8:35 am 125%
currently there is some problem with non integer font scaling
Daimonicon
xnview wrote: Tue Jun 24, 2025 12:06 pm currently there is some problem with non integer font scaling
Yes, I've heard that before - I think the whole operating system is an annoyance. So there's no option via the settings and because of these problems you don't plan to add this option I guess?
I almost managed to do it via the theme files (style_sheet.qss etc.). Could you maybe think about adding comments to a yxz.qss as an example that you can learn what is what or maybe a tutorial for this ? A suitable naming would also be helpful (style_sheet_default.qss, style_sheet_dark.qss, style_sheet_bright.qss).
In my case I urgently need the theme “hell” *de - presumably bright/light in english. Because this theme had the sharpest font display which is already helpful without changing the font size.
