Hi there,
I'm using xnviewmp portable 1.9.2 64 bit on a laptop with windows 11 pro 24h2 - Windows Feature Experience Pack 1000.26100.107.0
It doesn't matter what I do, the right click mouse button doesn't change into a hand to move the large image around.
The mouse settings are correctly set to right mouse button 'Pan Image'.
I'm not a inexperienced user, so it has to be a bug in the portable version? What's wrong?
Right mouse button 'Pan Image' not working [Solved]
robxnviewmp
Re: Right mouse button 'Pan Image' not working
RMB - Pan (pan if image>window)
Shift+LMB - Zoom&Pan (zoom image to 100% and pan)
robxnviewmp
1- The (pan if image>window) option isn't available at settings, or what does that mean?user0 wrote: Thu Jun 19, 2025 11:25 am RMB - Pan (pan if image>window)
Shift+RMB - Zoom&Pan (zoom image to 100% and pan)
2- I don't want to use the shift key
it's just the default command for RMBrobxnviewmp wrote: Thu Jun 19, 2025 11:34 am The (pan if image>window) option isn't available at settings
show screenshot of the app window with image you are trying to pan
also check trackpad settings, manufacturer's software may have some weird settings
robxnviewmp
Thank you for your patience and willingness to try to solve the problem.
It turned out that another program (Quick Click) caused the issue.
Thanks again!
Thanks again!
