XnviewMP working incredible Slow
TGB_72
Post by TGB_72 »
XnviewMP is taking way more time to load thumbs in the browser and also to load images in the viewer (any type). I notice this drawback after v1.8.0 (the last fine version). I don't know the exact version where the problem was intruded but certainly was between v1.8.1 and v1.8.3 and persist until the last v1.9.2.
I'm using XnvewMP on Windows 10 64bits with a ryzen 5700x and 32GB of RAM.
Re: XnviewMP working incredible Slow
which format do you load in viewer?
TGB_72
Post by TGB_72 »
Hello Pierre,
Mostly jpeg, png, bmp and psd.
do you have a lot of files in the folder opened? do you open in viewer an image file from browser?
TGB_72
Post by TGB_72 »
It work slow regardless of the number of files, the browser take some seconds to load the thumbs not matter if there is 1 or 50 pictures, anyway I'm not using it with folder with more than 200 files. Otherwise I've set XnviewMP to open in browser mode and yes then from there I use to open images in the viewer. Like I said before now I'm using v1.8.0 and works with no problems, this issue was introduced after this version.
TGB_72 wrote: Sun Jun 22, 2025 6:32 pm Otherwise I've set XnviewMP to open in browser mode and yes then from there I use to open images in the viewer. Like I said before now I'm using v1.8.0 and works with no problems, this issue was introduced after this version.
I can't reproduce. Please send us your xnview.ini?
TGB_72
Post by TGB_72 »
Hello Pierre, I made a fresh OS and XnviewMP installation and the issue seems to be gone, at least v1.92.works fine just like v1.8.0, thanks for your support.
TGB_72 wrote: Tue Jun 24, 2025 8:40 pm Hello Pierre, I made a fresh OS and XnviewMP installation and the issue seems to be gone, at least v1.92.works fine just like v1.8.0, thanks for your support.
do you have always the old xnview.ini?
TGB_72
Post by TGB_72 »
Unfortunately not, I had other issues with Resolve too so monday I made a fresh OS installation after format and reinstalled everything included XnviewMP. Fortunately all seems to work fine now.
