[SOLVED] INFO panel (in viewer) doesn't show all Exif data
bemymonkey
Post by bemymonkey »
Hello there,
I'm having a strange issue and I'm wondering if this is something that's known to be an issue or may be something new: The Info panel in the top left of the screen in the viewer (and full screen) doesn't always show all the contents of all the EXIF fields I'm trying to have visible.
As an example:
{EXIF:Model} {EXIF:Lens Model}
({EXIF:Focal Length 35mm}mm@35) -  {EXIF:Focal Length}mm {EXIF:Shutter Speed}s {EXIF:Aperture} ISO{EXIF:ISO Value}
results in:
Nikon D850
(35mm@35) - 35mm s ISO64
As you can see, Lens Model, Shutter Speed, and Aperture are missing.
However, when I check the actual EXIF data using the info panel in the browser view, these fields are clearly populated with values. The browser also displays these values under the image thumbnail without any problems - it's only the Info field in the viewer that has the issue.
The images are JPG images SooC from a Nikon D850. Interestingly JPGs processed from RAW using Adobe Camera Raw from the same camera don't display this issue.
I'm running XNView 1.9.1 64bit (Linux) - Libformat 7.226, which is the latest available Flatpak. I have verified that the issue also occurs with the latest available AppImage. I'm not entirely sure, but I can't remember this happening on Windows - if that's worth pursuing I can check next week when I'm back within reach of a Windows machine.
I can supply sample images if required, please just give me a heads up if that is the case.
Franky
Re: INFO panel (in viewer) doesn't show all Exif data
Post by Franky »
hello,
With the Windows version, some info is also missing
Franky
Post by Franky »
You can try with {EXIF:F-Number} and {EXIF:Exposure Time}
bemymonkey
Hi Franky, thanks for the quick reply, that's an excellent workaround!
Of course I'm still interested in why it's happening - were the field names I was using simply incorrect?
Franky
Post by Franky »
You can check which labels are used for the Thumbnail.
It's in Settings/Thumbnail/Labels
bemymonkey
Thank you Frranky!
I've since done some Googling and followed up using exiftool: Apparently the Nikon SooC JPEGs really don't include these fields!
JPEG SooC:
simon@simon-deb-p14s:~/Temp_Pictures_Sync$ exiftool -exif:all SLB_3418.JPG
Make                            : NIKON CORPORATION
Camera Model Name               : NIKON D850
Orientation                     : Horizontal (normal)
X Resolution                    : 300
Y Resolution                    : 300
Resolution Unit                 : inches
Software                        : Ver.1.31
Modify Date                     : 2025:06:19 12:01:52
Artist                          :
Y Cb Cr Positioning             : Co-sited
Copyright                       :
Exposure Time                   : 1/320
F Number                        : 2.0
Exposure Program                : Program AE
ISO                             : 64
Sensitivity Type                : Recommended Exposure Index
Recommended Exposure Index      : 64
Exif Version                    : 0231
Date/Time Original              : 2025:06:19 12:01:52
Create Date                     : 2025:06:19 12:01:52
Offset Time                     : +00:00
Offset Time Original            : +00:00
Offset Time Digitized           : +00:00
Components Configuration        : Y, Cb, Cr, -
Compressed Bits Per Pixel       : 4
Exposure Compensation           : 0
Max Aperture Value              : 2.0
Metering Mode                   : Multi-segment
Light Source                    : Unknown
Flash                           : No Flash
Focal Length                    : 35.0 mm
User Comment                    :
Sub Sec Time                    : 41
Sub Sec Time Original           : 41
Sub Sec Time Digitized          : 41
Flashpix Version                : 0100
Color Space                     : sRGB
Exif Image Width                : 6192
Exif Image Height               : 4128
Interoperability Index          : R98 - DCF basic file (sRGB)
Interoperability Version        : 0100
Sensing Method                  : One-chip color area
File Source                     : Digital Camera
Scene Type                      : Directly photographed
CFA Pattern                     : [Red,Green][Green,Blue]
Custom Rendered                 : Normal
Exposure Mode                   : Auto
Focal Length In 35mm Format     : 35 mm
Scene Capture Type              : Standard
Gain Control                    : None
Contrast                        : Normal
Saturation                      : Normal
Sharpness                       : Normal
Subject Distance Range          : Unknown
GPS Version ID                  : 2.3.0.0
Compression                     : JPEG (old-style)
Thumbnail Offset                : 21552
Thumbnail Length                : 12261
Thumbnail Image                 : (Binary data 12261 bytes, use -b option to extract)
Edited with ACR:
simon@simon-deb-p14s:~/Pictures/Friends_Events/Sorted/2024-10-23 - South Thailand Road Trip$ exiftool -exif:all 2024-11-12_11-06-05-D850.jpg
X Resolution                    : 300
Y Resolution                    : 300
Software                        : Adobe Photoshop Camera Raw 17.0 (Windows)
Modify Date                     : 2024:11:20 21:12:55
F Number                        : 2.8
ISO                             : 110
Recommended Exposure Index      : 110
Exif Version                    : 0231
Date/Time Original              : 2024:11:12 11:06:05
Create Date                     : 2024:11:12 11:06:05
Offset Time                     : +01:00
Offset Time Original            : +07:00
Offset Time Digitized           : +07:00
Shutter Speed Value             : 1/320
Aperture Value                  : 2.8
Max Aperture Value              : 2.8
Flash                           : No Flash
Focal Length                    : 34.0 mm
Sub Sec Time Original           : 08
Sub Sec Time Digitized          : 08
Color Space                     : Uncalibrated
Focal Plane X Resolution        : 2301.324615
Focal Plane Y Resolution        : 2301.324615
Focal Plane Resolution Unit     : cm
White Balance                   : Auto
Focal Length In 35mm Format     : 34 mm
Gain Control                    : None
Contrast                        : Normal
Saturation                      : Normal
Sharpness                       : Normal
Serial Number                   : 6012809
Lens Info                       : 24-70mm f/2.8
Lens Model                      : 24.0-70.0 mm f/2.8
Thumbnail Offset                : 1050
Thumbnail Length                : 19681
Thumbnail Image                 : (Binary data 19681 bytes, use -b option to extract)
Note that the ACR-edited version includes both Exposure Time as well as Shutter Speed Value, in addition to both F Number as well as Aperture Value. SooC JPEG only has F Number and F Number, respectively.
Hence: Not an XnView issue!
