Detach map panel from Info panel
PrintProf
Post by PrintProf »
Hi. I love (mostly) XnView, but there are a couple of little things that would make my life a lot easier.
Is there any way to detach the map panel from the other tabs in the info panel and have it located next to the properties tab? In other words, have the properties and map panels open at the same time without having to switch between them? It is possible to do this with other tabs like histogram, preview, and metadata, but I can't figure out how to detach maps.
Thanks in advance for any help or suggestions.
Re: Detach map panel from Info panel
currently no way but it's in the TODO list
