XnConvert Manual?
auntmare
XnConvert Manual?
Post by auntmare »
Question, is there any sort of manual or help files for the XnConvert program? I have scanned many photos into Tiff files and want to simply convert them to jpeg for sharing with family. I would appreciate any help you could give.
Re: Manual
Documentation for XnView software is in practice quite limited and often not current as new options have been added and menus rearranged.
However, XnConvert (nominally identical to the batch convert option in XnView MP but updated separately) has a particularly simple and attractive interface, much of which can be deduced by viewing the tabs from left-to-right. For detailed help when needed post under the XnConvert heading of the forum.
auntmare
Re: XnConvert Manual?
Post by auntmare »
I believe I'm getting the hang of it, but thank you for your kind reply. As long as I don't lose any originals, I'm fine. Have a good day..
auntmare wrote: Wed Jun 25, 2025 5:18 pm I believe I'm getting the hang of it, but thank you for your kind reply. As long as I don't lose any originals, I'm fine.
Always test with copies of files when there could be any risk of an unforeseen unpleasant surprise... :wink:
