When F7 is pressed, a new directory is created. The name of the new directory is New Folder 1. This is, of course, never what I would like to call the directory. Therefore, it needs to be renamed.
In XnView, the directory name is automatically selected, meaning that after pressing F7 one can simply type the desired directory name and press enter. In XnView MP, the directory name is not selected, meaning that in order to rename it, it needs to be selected first by shift-home or ctrl-A, I suppose. Something requiring multiple keypressed in any case, making this more cumbersome.
The suggestion is to make this work the same way as in XnView, i.e. after the directory has been created with the template name, the name is selected so that the new name can be immediately typed.
Better handling of F7 desired
Re: Better handling of F7 desired
its already like this in 1.9.2Asam wrote: Fri Jun 27, 2025 9:41 am ..after the directory has been created with the template name, the name is selected so that the new name can be immediately typed.
rename your xnview.ini if you upgraded from some old version and still have this issue
Asam
I renamed xnview.ini and reconfigured. It didn't help.
Asam
When pressing F7, it seems that "New Folder 1" is briefly selected, but the cursor is almost immediately moved to the end of the text, unselecting it. OS is Windows 10, by the way.
issue is caused by [Browser] onTheFly=true and Details view
