______________________________________________________
XnView: MP 1.92- 64 bit
OS: Windows 10 64 bit
Effect: Enter does not close fullscreen
1. Under Switching modes, Enter has been configured Browser <-> Fullscreen | Viewer <-> Fullscreen.
2. In browser, enter is pressed. Image opens in fullscreen.
3. Enter is pressed again. Nothing happens.
4. Enter is pressed again. Browser is very briefly seen and the image is again opened in fullscreen.
This bug cannot be always reproduced, but it is not rare either.
Actual behaviour (bug): In step 3, fullscreen image remains visible instead of the browser.
Expected behaviour: In step 3, fullscreen image is replaced by the browser window.
1.9.2: Enter does not always close fullscreen
Re: 1.9.2: Enter does not always close fullscreen
rename your xnview.ini or make clean install
Asam
I renamed xnview.ini and reconfigured everything. The problem persists.
please send us your .ini?Asam wrote: Mon Aug 04, 2025 4:15 pm I renamed xnview.ini and reconfigured everything. The problem persists.
Asam
Sure, it's attached. I renamed it into a jpg because that was the first extension I could think of that was accepted by the forum.
Asam
Hmm, I suppose the attachment didn't work after all. Let's have another try. This time it's been gzipped.
i've tried but can't reproduce, enter always quits fullscreen. Please check the 1.9.3
Asam
In order to reproduce, try browsing images with Page Down faster than XnView can keep up with them, then press Enter and wait until all keypresses have been processed. I'm not sure if that's needed but I think that's often been the scenario where this has happened.
Then again, I haven't seen this with 1.9.3 yet, so this may indeed have been fixed.
Asam
This happened with 1.9.3 as well. Not browsing through a lot of images (although plenty of them were present). Enter would briefly close the image and immediately reopen it in fullscreen. Esc would not close the image.
Please wait the 1.9.4 to retest...
Asam
Happens with 1.9.8 as well.
you are able to reproduce each time with 1.9.10?
Asam
Yes. It does not happen at the first attempt, but after a short while this starts happening. It doesn't seem to require a large amount of images either. The only way out of this I've found is to switch application with alt-tab and then return back. Then it will soon happen again.
