Steps to batch detect and correct orientation of scanned jpg's
thinders
Post by thinders »
I have inherited over 10,000 scanned photos, none have any EXIF data regarding orientation (or rather the EXIF data looks like it has the scanned orientation).
Some photos are off by 90 (L or R)some by 180
Mostly family, landscape (eg beach, picnic etc)
Can the app recursively go through a folder and detect / correct orientation and save any changes?
If so, what are the steps.
ACRizona
Re: Steps to batch detect and correct orientation of scanned jpg's
Post by ACRizona »
Some years ago, using WinBatch (scripting language(like Python)) to 'screen-scrape' and gather resolution, margin size, and other info before displaying, the viewer (XnView) then prompted you that this image "needs attention".
The prompter showed a GRID marker for every test. Dimensions, Resolution, etc, etc.
Note: most of these JPGs came from office-scanners, most everything was 'letter-sized'.
The operator had to view the re-sized image, then 'mark-'off' the GRID to continue.
Every modified image was saved (before/after).
"Upside-down" "leaning" and other un-seen problems are flagged in the GRID for later repair & verification.
The experienced operator could 'verify' a scan in seconds. Often, the image was simply junk, upside-down, blurred, whatever, the 'lock' could be checked in the GRID, meaning, the image is re-queued for later editing.
The WinBatch program used a simple SQLite 'tracking' database in this record-keeping application.
The WorkFlow programs used this database to move the documents thru the system, and finally, archive them in permanent optical-disk-juke-boxes !
Obviously, this is a large-scale application common to Government record-keeping. The emphasis was to speed the input-process for high-volume work, and minimize operator training.
The scripting does little more, than what XnView can do with proper training.
With all the effort$$ described above, we failed to automate "CROP" and "ROTATE" ! :wink:
