1.9.2: Blank Map despite GPS Data
christb
Post by christb »
XnView: MP 1.9.2 - 64-bit
OS: MacOS Sonoma 14.7.5 - 64-bit
XnView shows blank Map (all white) for Images containing GPS data. Open "GPS Location in > Google Maps" shows location correctly.
Effect: Visual Glitch > Map Module blank
1. Select image with GPS Data.
2. Open "Info Panel > GPS (Map Tab)" or "Properties > Map Tab"
Actual behaviour (bug): Map Tab is blank (all white) :bug:
Expected behaviour: Map and pin showing.
Re: 1.9.2: Blank Map despite GPS Data
sorry but i can't reproduce on MacOS 15
nburrell
Post by nburrell »
I am seeing the same problem with MacOS 13.2 - used to work perfectly until a couple of releases ago
nburrell wrote: Fri May 08, 2026 4:07 pm I am seeing the same problem with MacOS 13.2 - used to work perfectly until a couple of releases ago
intel or arm?
nburrell
Post by nburrell »
intel
nburrell wrote: Tue May 19, 2026 11:55 amintel
right, it works on arm, and not on intel
cicciobello
Post by cicciobello »
christb wrote: Sun Jun 29, 2025 10:37 am XnView shows blank Map (all white) for Images containing GPS data. Open "GPS Location in > Google Maps" shows location correctly.
Same bug.
MP 1.11.1 x64 - Win 10 x64 LTSC - CPU AMD
jkm
Post by jkm »
1.11.2 map is working fine for me on Win 7/10 x64 on Intel.
