Curve Presets not saving properly? [1.9.2 W10 64b]
meteorquake
Post by meteorquake »
For Image - Adjust - Curves
when I adjust Red and Blue and save as preset, if I subsequently open the saved preset it doesn't restore the levels I used.
1.9.2 W10 64b
Let me know if any issues reproducing.
d
Re: Curve Presets not saving properly? [1.9.2 W10 64b]
This problem is supposed to be fixed in XnView MP 1.9.3. Please check and confirm the bug fix here.
