Filter by EXIF tags
jkm
Filter by EXIF tags
Post by jkm »
It would be fantastic if XnViewMP could filter images in the browser by EXIF values.
For example:
Show images with Aperture=5.6
Show images with ISO>=1600
Show images with ShutterSpeed>=1/30
Being able to combine any of these would also be very helpful.
As an addition to the above, or even instead of to simplify user interface changes, instead of a full GUI with drop down menus and pick lists for the values, there could be a simple text box entry that could contain things like this:
{EXIF:F-Number}=5.6
{EXIF:ISO Value}>=1600
{EXIF:F-Number}=5.6&{EXIF:ISO Value}>=1600
Each line above is a separate example of a filter. & for AND and | for OR.
This functionality would really be a wonder addition! Pretty please? :D
Re: Filter by EXIF tags
[Advanced] Search (Ctrl+Shift+F) exists for exactly this purpose
jkm
Post by jkm »
Thank you, but the fields it can search are very limited, and it can't search makernotes at all.
Searching "all fields" to overcome the limited exif selection returns incorrect/ambiguous results when two different fields (which cannot be individually selected) contain the target value.
The current advanced search doesn't meet my needs.
jkm wrote: Thu Jul 03, 2025 12:57 am instead of a full GUI with drop down menus and pick lists for the values, there could be a simple text box entry that could contain things like this:
sure, which symbols are you going to use for 'contains', 'starts with' conditions?
advanced search GUI exists in the most apps for a reason
the only limitation I see - global OR/AND
but I don't recall any app that uses separate matching option at condition level
if you need any new EXIF tag - make a separate topic with such specific request
Post by michel038 »
FastPhotoTagger (freeware .jar app) can work on any tag managed by ExifTool... even in it's DataBase, and queries can be built with "And" and "OR" for each tag
But it's not as convenient as Xnview
santa777
Post by santa777 »
I second filtering by more EXIF tag options. I am missing the option of sorting pictures by Camera Model or Lens.
ACDSee has both of these options
